Greddy SE exhaust extra bracket?
Greddy SE exhaust fitment 76mm??
I think 76mm 2.75 pipe or if other clearance similar from other single exhaust set up?
Previously without the bracket/hanger had the muffler sit center but had the following problems
- rubbing frame on hard turns and any full wheel lock turning.
Now it still rubs frame sections at random areas but much less and seemingly lighter than before but muffler not sitting straight. Somethings going to give eventually... exhaust or frame? Or will it actually grind enough to the point where no structural compromise occurs?
Is it the hangers? if so which are recommended or should I acquire some oem ap2 triangle?
