Sponsored by: CARiD
Hardtop Brackets
Old Jan 8, 2014 | 08:14 AM
gello2024's Avatar
Default Hardtop Brackets
Hey everyone,
I am looking into getting Izzys rear hardtop brackets. Does anyone have these one with pictures they can share? Id like to see how they are set up on the hardtop. I cant seem to find any images online for them.
And as a side topic, anyone recommending other brackets to secure the hardtop properly?
Old Jan 8, 2014 | 09:51 AM
s2000vtecvtec's Avatar
if they are same as the brackets forbidden usa used to sell, those brackets are garbage. they vibrate and flex a lot because too thin. and it's PITA to take hardtop on and off.
Old Jan 9, 2014 | 12:27 PM
Forbidden-USA's Avatar
Former Sponsor
We do not use Izzy brackets. We have two new designs now then what you use to have 2 yrs ago.
1 Piece
http://www.forbidden-usa.com/product_p/frbn-bkets.htm
2 piece (oem style brackets)
http://www.forbidden-usa.com/product_p/frbn-oe-brks.htm
Alberto
Old Jan 12, 2014 | 03:48 PM
i hope you won't disappoint people after these replica hardware. your one piece hardware is just junk.
Old Jan 13, 2014 | 09:24 AM
StormTroopinAP2's Avatar
do you have any suggestions for the OP?
Old Jan 13, 2014 | 09:46 AM
yamahaSHO's Avatar
I was looking at mine the other day wishing they were steel as the aluminum is pretty thin. I'm going to install mine for a test fit this week and see how mine do.
Old Jan 13, 2014 | 10:36 PM
boyguan's Avatar
The design is good but because its aluminum it flexs easy which allows the top to move. If it was steel or had some bracing it the back it would be much better
Old Jan 14, 2014 | 12:12 PM
Former Sponsor
Stronger does not mean better. Let me explain
If you use steal brackets, the top will be so stiff it will not allow flex with the body roll of the car. Therefore, it will create tension which will create noise.
If you own a hardtop, go up and drive way and see how much much tension is being created due to the body roll. Now imagine if you had steal brackets and your top couldn't flex with the body roll of the car.
Alberto
Old Jan 14, 2014 | 12:36 PM
MBHs2k's Avatar
Agreed with Alberto. Same reason why you don't torque the nuts too tight either. You need a little play to prevent creaking. Anyways, all of the one piece hardware available for hard tops is junk
Old Jan 14, 2014 | 01:17 PM
s2kreeper's Avatar
Alberto
I think the real answer here is to get a cage to eliminate chassis flex .
