HELP on Schroth Profi II Harness Install
How do you mount the Schroth Profi II passenger-outside lap belt on an '06?
List of items to be installed:
Recaro SPG
Schroth Profi II
Double diagnol Harddog bar w/ lower harness bar
HANS
Im installing Schroth Profi II (6pt) on my '06 tomorrow. Ive been looking over this install for some tips... https://www.s2ki.com/forums/index.ph...#entry15824923.
If I understood correctly....
As you can see there is no hole to bolt the eyebolt.
For those w/ '06+ s2ks w/ the Profi II, how did mount the passenger harness? Do you have a photo of the process? Any help is greatly appreciated! Thanks in advance!!!
Recaro SPG
Schroth Profi II
HANS
- sub belts will be connected via eyebolts bolted through the floor (w/ backing plates)
- shoulder belts will be wrapped around the harness bar (lower Harddog bar)
- lap belts will be connected via eyebolts
- the outside eyebolt bolted to the OEM seat belt hole
- the inside eyebolt will need to be drilled & use the backing plate
I haven't done this on this car, but it looks like you will have to drill and set either a stnadard belt eyebolt, or a tab mount with an eye at the top. Its all about the reinforcement, so it may be easier to install on the floor, not the sill.
^ Thanks! I was looking at possible places to drill a hole for the bolt/backing plate. There is a angled (albeit flat) area, probably about 45* w/ the floor board, that I can drill a hole through & fit a backing plate. Anyone think its wrong to mount the eyebolt to the angled section? I'll have to take a photo of of the area Im talking about.
iLuveketchup
08-10-2010 09:50 PM
The Driver
09-16-2003 10:45 AM
