j's front camber joint
hey guys
if i was to get the j's front camber joint (not with the roll centre adjuster plates), how are they adjusted? can they be adjusted? or do they just "add more camber range" to the stock camber points. for example: front camber is -1.7. add on the camber joint = instant -3.0 degrees or max front camber is -1.7. add on the camber joint = camber range increases to -3.0 degrees max. any info would be much appreciated!! p.s. (numbers are just random figures lol) |
anyone? lol
They are not adjustable. They simply offset the balljoint which will push your knuckle outwards. This gives more negative camber than what is available with the stock adjustment range.
Basically it makes your overall adjustment range more negative and you still use your stock camber bolts to adjust camber. |
Basically it makes your overall adjustment range more negative and you still use your stock camber bolts to adjust camber. all i needed to know =D thanks glagola1!! |
| All times are GMT -8. The time now is 11:10 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
