Least Invasive Roll Bar
All,
I just recently purchased a 2000 s2000. I have only put about 100 miles on it and I can already say it is my favorite car I have ever owned. My car is as of right now untouched as far as modifications. I would really like to put a 4 point roll bar in but I do not want to hack up the interior panels, should I ever want to revert to stock appearance. Are there any options out there that do not require panel modification? If not what could I buy that would require the least panel modification or maybe even just require me to buy additional panels to replace hacked up ones. I have been looking at the spoon sports roll bar, is this a good option? Some additional information that may be helpful is that I plan to recover the soft top because my vinyl window is already cracked. I may also get a hard top down the road. Please help this newbie.
Thank You
Thank You
RogueMotorsports (06-22-2018)
Why do you need a roll bar? Planning to track car? You really don't need or want a roll bar for street, the OEM rollover protection is great on the s2000.
If you do go roll bar go Hard Dog style, you will need to either trim interior or leave it out and fender well will need trimming.
Google it there are loads
I'm looking for the same thing, a minimally invasive roll bar.
I don't like the install of the hard dog, in that you need to cut all sorts of access panels to mount it.
The Cusco is better, it fits around the factory roll hoops, but you looks an inch or two of seat travel, and looks like it might cause the soft top to bunch up.
I don't know, I looked at a lot of them and haven't found one I liked.
I'm thinking about fabricating my own that bolts to the stock roll hoop locations and bolts to the rear shock towers so would also be a rear chassis stiffener like the CR, and would have custom plastic hoop covers made.
Sadly just don't have the time to do this at the moment
Its one or the other, Cusco is not functional and not scca/nasa approved. Hard hog or RSG or Ballade will give rollover protection.
You cant not hack something up yet get great protection.
I disagree. I've personally seen it work spectacularly well. Moreover, you can search high and low on this and other forums and on the Internet and you will not find one instance where anyone has experienced or witnessed it's failure.
Were I to again install a roll bar in my S2000, it would certainly be a Cusco (Safety 21).
That part of your statement that It is not approved by a USA sanctioning body is true.
