LED in high beam & DRL?!?!?!
#21
I tried this one more time and this is the final time I try.
I put the same leds back in without resistors or anything and they worked fine for a couple of days. One stopped working and blew the fuse to my low beam for whatever reason. Removed them and order a new pair of LEDs + a h1 decoder. Plugged everything up and it worked fine for a few minutes then stopped. The drl function is eliminated, no drl light on the dash either but the LEDs work as high beams. Strange as hell.
Tried connecting the plugs in various combinations and got nothing so I officially give up unless someone comes up with a genius idea.
Back to Nokya hyper yellow bulbs for me.
Here are the links to the LEDs and decoder I used.
1st LEDs which stopped working: https://www.ebay.com/ulk/itm/282282448774
2nd LEDs which worked for a few minutes as drls then only worked as high beams: https://www.ebay.com/ulk/itm/282160334151
The decoder used: https://www.ebay.com/ulk/itm/142146285575
All in all I learned that simply plugging in LEDs will work for a few days max, then the low voltage will burn out the LEDs. The decoder did nothing but work for a few seconds and got rid of the DRL light on the dash even tho the DRLs wouldn't turn on.
Stick to halogens
Stick to halogens
#22
Thanks for the research.
I'm astounded you could replace the bulbs so many times! Took me what seemed like an hour go change the high beams (to brighter halogens) two summers ago as there is no way even my small hand will fit in there!
-- Chuck
-- Chuck
#23
Sponsor
Reviving this thread to provide a solution. We now have a custom harness + LED solution that will allow any S2000 00-05 or 06+ or DRL equipped S2000s to upgrade to LED High Beams and DRLs.
https://www.s2ki.com/forums/s2000-mo.../#post24519948
DRL + High Beam + Custom Harness: Supernova LEDs DRL + High Beam LED Headlights (Pair) - $119.99 : JS2K.com!
High Beam LED only: Supernova LEDs High Beam Only (Pair) - $59.99 : JS2K.com!
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
#25
Sponsor
Yes, both are the same output. We tested them during the daytime, they're bright, but they're not too bright.
__________________
_________
_________
Saki GT
03-22-2024 12:56 PM
