Megan racing
Hi all,
what are the two washers supplied on the balljoint end for, they are about 5mm thick.
Sorry I cant provide pics, hopefully someone that has fitted these will read.
Joe
Joe
You have 3 washers, a big one and 2 smaller ones. the clue is to reposition the toe arm further away from the knuckle with the use of the washers, so that the bumpsteer will be reduced.
Some alignment shops have measurment tools for this, but i seey you have a '01 spec s2k with probably oem 16"wheels, so you cannot use all the washers otherwise you will hit the rim and might need to grind some off the lower nut to get the rims back on.
Mr-T
Dec 3, 2013 12:45 AM
Ricgreen
Oct 6, 2007 12:20 AM
