MY 2006 Hondata Reflash is OUT!
http://www.hondata.com/reflash_s2k_06.html
VTEC point decreased from 6000 rpm to 5600 rpm Rev limit 8500 rpm Maximum torque gain 14 ft/lbs torque at 5800 rpm Maximum power gain 16 hp at 5800 rpm Fully dealer compatible - works with all Honda scan tools and equipment http://www.hondata.com/reflash_s2k_toda_header.html VTEC point decreased from 6000 rpm to 4200 rpm Rev limit 8500 rpm Maximum torque gain 20 ft/lbs torque at 5800 rpm Maximum power gain 23 hp at 5800 rpm Fully dealer compatible - works with all Honda scan tools and equipment $595 for either |
That's with Toda Header.
This is on a stock '06: VTEC point decreased from 6000 rpm to 5600 rpm Rev limit 8500 rpm Maximum torque gain 14 ft/lbs torque at 5800 rpm Maximum power gain 16 hp at 5800 rpm |
WOW.... $$?
"The 06 S2000 is the first S2000 by Honda to have a programmable ECU. Our observations are that this is a very well tuned car from the factory. There were no peak power gains, but by raising the rev limit will increase the average power available when you shift at the rev limit."
Gotta pull the ECU and ship it in for the reflash. Seems like a lot of money and trouble for minimal gain, at least compared to the gains the similarly priced (and no ECU pulling required) Cobb AccessPORT provided my '05 Saabaru (+25hp, +25 ftlbs). With the header, however... |
those are some nice midrange gains
yeah the gains only seem worth it with the header. I'm actually dissappointed with Hondata on this one, they usually can do some pretty impressive stuff, guess Honda just has the S2000 dialed in. Who would have thought?? :confused: :rolleyes: ;)
Originally Posted by notyou,Apr 25 2006, 08:52 AM
Seems like a lot of money and trouble for minimal gain, at least compared to the gains the similarly priced (and no ECU pulling required) Cobb AccessPORT provided my '05 Saabaru (+25hp, +25 ftlbs). With the header, however... Overall, i see a lot of owners (atleast the ap2s) swapping to 06 ecu for this reflash and the 06 really got hooked up this time. I will definitely be doing this swap. |
I assume that's 16 whp? If so, aside from the trouble of pulling the ECU, it's a lot of bang for the buck.
On a side note, isn't 4200 a low VTEC point for having just a header? I guess I could see it on more heavily modified or FI cars. (just curious) |
vtec engagement from 4200-8500. I think i'll like that.
