Need help on 15mm hubcentric spacer w Integrated Stud
Old 02-24-2016, 04:44 PM
  #21
99SH's Avatar
Yes, the inner race gets stuck on the hub.
Old 02-24-2016, 07:38 PM
  #22
Le7316's Avatar
Yes to ? Can you elaborate bro ?
Old 02-24-2016, 07:54 PM
  #23
99SH's Avatar
When you extract the hub, the inner race of the wheel bearing is attached to it (pressed fit).
Old 02-24-2016, 09:49 PM
  #24
Le7316's Avatar
Your telling me that I can't remove the hub unless I have the press or I will have to cut the race and then use one of the hammer slide tool set ?
Old 02-25-2016, 05:21 AM
  #25
99SH's Avatar
1. You remove the hub by either a slide hammer or using a shop press
2. Once hub is removed, the bearing inner race will be attached to the hub
3. You need to remove the inner race using a shop press + gear puller, or any other suitable tool
A press is much cleaner and easier. The slide hammer IMO will take more time because you're trying to work around everything (on re-installation).
Old 02-25-2016, 06:57 AM
  #26
Le7316's Avatar
Got it and appreciate it man .This is going to be a weekend project . Now , since I am replacing the stock studs and I'm assuming when your buying the DRS series from H&R they will provide the studs with the hubcentric spacers regardless of the size ( 15mm , 20 etc ...) ?
Old 02-25-2016, 04:24 PM
  #27
99SH's Avatar
Per H&R website, they indicate studs are included.
http://www.hrsprings.com/products/trak/
DRS® Series
6 - 40 mm track widening
DRS Series spacers fit between the wheel and hub, and require exchanging the existing wheel studs for longer ones (studs are included).
Old 02-26-2016, 01:52 AM
  #28
Memo6453's Avatar
am i missing the reason for not just using a spacer with integrated studs already?
Optionselect
Ichiba v2
Project kics
10-12-15-17mm
Old 02-26-2016, 05:53 AM
  #29
Le7316's Avatar
Memo6453 ,
Thank you for the info but ,
1) Project Kics deos not carry 15mm " Hub Centric " w studs built in
2) I prefer not to use Ichiba V2 after all the horror stories ppl almost died with studs broken off..etc ...
3) Optionselects - I couldn't find those anymore ---not sure where you guys got those .
Old 06-23-2018, 12:45 PM
  #30
Mugen_is_best's Avatar
To revive an old thread with first hand experience, the ichiba wheel studs are no good. I have been using them for about a year and three studs on one wheel. broke off. I wouldn't suggest using these spacers without pressing in new studs.
Quick Reply: Need help on 15mm hubcentric spacer w Integrated Stud
