Need help on 15mm hubcentric spacer w Integrated Stud
Guys,
I can't seem to find anyone with 15mm front (center bore 70.1 w studs built in ) that is bolt-on. Does anyone know where I can get 15mm front bolt-on? I do not want to remove hub for extended studs. Ichiba only has rears, optionselects does not have 15mm, and H&R does not have the bolt-on spacers.
Thanks
Thanks
Dobleu (03-03-2022)
These are the 15mm ones I have and they are on sale right now...
I have the same brand 17mm in the back and I'm dropped on tein s-techs on stock tire sizes.
The quality is good and I haven't had any issues with them.
I'm not rolled and I rub slightly on really big dips.
http://www.ebay.com/itm/171386996255...%3AMEBIDX%3AIT
Thanks Chubbys2k for your info .
I believe they are hubcentric. Read this description
http://www.jscspeed.com/catalog/H_R_...0-14715-1.html
You're right ! It is a hubcentric but looks like there is something different in the thread .. 1/2 UFN I'm not sure what that means . The JSCspeed doesn't show 15mm DRM but DRS ...but then evasive link showings there is 15mm DRM maybe for different car ? I guess it's all Come down to this " 1/2 UFN " number ? I believe we have 12x1.5 lug nuts on our S .
The evasive one might work but just not sure what's the " 1/2 UFN " stand for .....
I know Project Kics has one for 15mm but it is NOT hubcentric which I prefer not to use ... Not safe at all .
1/2" is the diameter of the stud, with UNF indicating a fine pitch thread (20 TPI -threads per inch). So you'll need to purchase 1/2"-20 lug nuts to go with the spacer.
FYI - the stock studs are metric, M12x1.50
