need help with installing the exhaust
if you raise the rear end of the car, you will see exactly where it is located. In fact, if you take out the muffler portion of your exhaust, it is very plain to see where the hanger goes there are two directly on the canister that go to the OEM hanger locations, and a third one protruding from the piping giong towards the center of the car. Once you have the exhaust hung up where it should be, the location of this bracket will be self explanatory
Hard to take a pic of the exhaust under a car without having it on a lift, and even then you wouldn't probably be able to see the hanger.
Obviously it has to go over 2 bolts, I haven't put on a t1r, but I'm guessing there are no more than 3 places where you have to bolt it together. When you take the stock exhaust off you will see where the 5 stock hangars are, so whichever location of the bolts is directly below a stock hangar, that is where it needs to go.
