Note to spc ball joint buyers!!!!!
This may have been the issue SPC fixed that has caused the interference. I ran them in a few autocrosses and had no slip issues. Granted, i'm only running 200 TW and i'm not a good driver, but increasing the grip length of the fastener would definitely prevent load loss and reduce slipping. And it would explain why they rub on 16"s now.
I believe i'm running the old version with the low profile nut on top, which I assume is what's changed. I don't ever plan on tracking with Hoosiers but do plan on moving from extreme summers to r comps. Hope I don't have slipping issues. I suppose thread locker would do nothing if its a matter of nut surface area/available trq, vs the nut actually coming lose. What do you guys thing is causing the slippage? Do you think thread locker would be worth wile?
I doubt the ones that slipped were properly installed.
Mine haven't slipped for years, after lots of track-off's and running 71R's. I've even spun into a curbing lip and bent a spindle...no sign of slip.
Yep.
And they're not adjusters anyway...so you really should set them once and forget they exist.
If one were afraid of slip, just weld them in place when you're happy with the setting.
