NRG Hood Damper - Not Vertical?
Old 03-19-2019, 03:42 AM
  #31
zeroptzero's Avatar
Received 3,358 Likes on 2,441 Posts
my NRG carbon dampers did not open the hood fully either, sounds like a design change to me, I bought mine within the last 2 years.
Old 03-19-2019, 03:51 AM
  #32
THE Z MAN's Avatar
Ok, a small poll to determine if there was a design change or a mismatch at NRG ...
So those of you who have the fully opening dampers,
what is the newest purchase year?
Mine is 08/2009
Old 03-19-2019, 06:52 AM
  #33
Chuck S's Avatar
Received 1,128 Likes on 991 Posts
These seem to be a solution in search of a problem. Standard setup works fine, costs nothing, and doesn't bend the hood if something goes wrong. Long hood barely clears my garage door when up though!
-- Chuck
Old 03-19-2019, 10:17 AM
  #34
K LO QUE's Avatar
Mine is from 01/10
Old 03-19-2019, 10:29 AM
  #35
Site Moderator
sam_spider's Avatar
Received 2,582 Likes on 1,900 Posts
Mine are NRG, about as vertical as you can get. I got mine back in 06 or 07, can't remember now.
Old 03-19-2019, 12:36 PM
  #36
THE Z MAN's Avatar
Chuck,
mine worked great for 10yrs without issues. If you have a cooling plate you can only use the hood prop on the max setting which isn't convenient
anyone else buy one recently with the full open position?
Old 03-19-2019, 03:40 PM
  #37
Hfreak's Avatar
My NRG dampers do not open as vertical as the old ones, mine were bought in 2016 I believe. If you are looking for close to 90 degree open on your hood then you should look into SOS, I have these as well and they are as close to 90 degree as you can get. Good luck.
Old 03-19-2019, 04:00 PM
  #38
alSpeed2k's Avatar
I'm quite sure they changed the design and you cannot buy the vertical ones anymore.
Old 03-19-2019, 05:56 PM
  #39
THE Z MAN's Avatar
A design change is what it seems like, but NRG hasn't mentioned any. they seem puzzled communicating with my vendor about the length issue.
interesting
lolls
12-22-2013 01:47 PM
Congo
06-11-2008 10:59 PM
robodeath
06-15-2007 05:41 PM
KeithD
08-30-2001 09:14 PM
Quick Reply: NRG Hood Damper - Not Vertical?
