OEM exhaust gasket between cat and exhaust
Originally Posted by 2003s2k2003,Feb 3 2009, 09:19 PM
Yes there is a gasket. It is a ring like gasket that crushes when compressed and seals the connection. I have been through a couple of them purchased at the dealership. I ordered a real exhaust gasket thing now to make sure it was a good seal on my HKS exhaust. Got it from Berk. Kinda expensive but it is the right shape which I couldn't find anywhere else and seals it up 100%.
http://www.slhonda.com/parts/wholesaleparts.htm
there are 2 gaskets.. there is a donut type gasket from the header to the cat. from the cat to the exhaust there is a round rubber gasket, that is not really visible from the outside. kinda sits in the piping almost.
Former Sponsor
As others have said, there is a crush ring gasket where the cat & cat-back meet. The ring sits inside a recess on the exhaust flange.
If you are using an aftermarket exhaust you need to use a gasket there. As far as I know, BERK is the only one who sells that gasket separately. We made it available to you guys primarily for those of you who buy exhausts second hand and don't get that gasket from the seller.
Hope that helps.
Hope that helps.
My 07 did not. I had to order one from the dealership. It was under $8. I just placed the order for this on Saturday. I told them I wanted the gasket between the cat and the exhaust.
Am I going to receive another crush gasket? Its no big deal, I haven't paid for the item yet.
I need a 70mm gasket though, can I cut the Berk gasket to size with some tin snips and be ok?
