quick question
i'm trying to install an strut bar that I ordered. I have to remove the strut bar bolts... how would I go about removing the bolts? Should the be car on the ground or do I have to raise it up? thanks
On the ground.
Jacking it up miiiiiiight make it a little easier as the strut towers won't be under any load, but the front of the S2000 is already pretty damn stiff, so either way should be doable without a problem. |
Strut bars are useless on the S.
Also, you'll have a very tough time removing the nuts without an impact gun. I took them off with the car on the ground. |
Nothing to worry about, just fit them with the S2000 on the ground.
