Rear Quarter Panel Question
Working on a left rear quarter panel replacement. Does anyone know if an AP2 panel will work with an AP1 (specifically year 2000)? I noticed the part numbers differ slightly (63300-S2A-300ZZ vs. 63300-S2A-310ZZ). Would hate to find out the hard way they are incompatible.
Side note: If anyone has a left rear panel, please let me know! |
pretty sure bumper tabs are different, otherwise identical
The holes for the taillights will also be different I believe
Originally Posted by jiepo
(Post 24554518)
https://cimg3.ibsrv.net/gimg/www.s2k...744dd2997e.gif https://cimg9.ibsrv.net/gimg/www.s2k...e2ff47bcec.jpg seam sealer goes between quarter and rear panel for tails. The bumper tab I was talking about its bottom side of quarter up close to the wheel. Otherwise should be identical. |
...so if you can't get the correct panel, perhaps you can meld old panel and new for these areas that are different. If those areas on old panel aren't damaged.
Or make a template off the good panel on the other side of car, then flip it to create a mirror image, to use to make a sort of patch panel for the correct taillight mounting holes. |
I just did this, it worked perfect. I keep the AP1 tail light holes on the car.
