Recaro Pole Position and BuddyClub Super Low Rails on 2006 AP2
I just installed recaro PPs on buddyclub seat rails.
I wanted the PPs for the longest time after sitting in a Porsche GT3 six years ago. Finally found the PP with the perfect material (red, jersey, and alcantara) from GT Motoring, Tim. I wanted to thank Tim for following up with me and great communication despite some bad reviews. Anyhow I wanted to write up a DYI for S2000 because none of existing ones tell you what exactly you need. First, you need an S2000 http://i130.photobucket.com/albums/p...000/photo3.jpg And a Recaro seat http://i130.photobucket.com/albums/p...o/e5d329cb.jpg And a BC rail http://i130.photobucket.com/albums/p...o/93341d2d.jpg And seat belt extension: http://www.4extender.com/ http://i130.photobucket.com/albums/p...o/e1cdbb82.jpg And 4 size M8 bolts. You need to buy these extra since these aren't supplied. Also don't forget 2 washers. http://i130.photobucket.com/albums/p...o/73520930.jpg You need one of these star shaped head for the air bag sensor removal from under the OEM seat http://i130.photobucket.com/albums/p...o/97a5fa2c.jpg Now just to verify the authenticity http://i130.photobucket.com/albums/p...o/3c1db39b.jpg I put some painters tape around the holes to protect the seat http://i130.photobucket.com/albums/p...o/167fc3a3.jpg Take out the original seat by unscrewing 4 bolts. http://i130.photobucket.com/albums/p...o/23feaaaf.jpg Make sure you Unplug the seat belt sensor and air bag sensor before taking it out all the way. Take out the air bag sensor from the OEM seat and plug it back in and leave it on the floor. http://i130.photobucket.com/albums/p...o/141d0a72.jpg It's the one on the left side in this picture. Don't pay attention to the seat belt receiver in this picture as I put it on the BC rail. Mount the BC rail like below. Notice how I ran the seat belt extension on the side. It brings the seat belt receiver all the way through the hole and be in a perfect position. http://i130.photobucket.com/albums/p...o/16ae189c.jpg Like so: http://i130.photobucket.com/albums/p...o/d55ce693.jpg Now is the hard part. Aligning the seat into place. I must have took out the seat like 20 times to adjust the BC mounts to fit the holes on the floor. Once you finally align it correctly, unscrew the bottom seat belt screw and run it through the left side hole on the seat http://i130.photobucket.com/albums/p...o/0d06a5b8.jpg And then screw it back in. http://i130.photobucket.com/albums/p...o/42e41aed.jpg Don't forget to plug in the 2 connectors. Seat belt sensor and air bag sensor. http://i130.photobucket.com/albums/p...o/4ac51fcd.jpg I used a towel to protect the back of the seat http://i130.photobucket.com/albums/p...o/2e29412d.jpg A wrench extension was very helpful http://i130.photobucket.com/albums/p...o/50d29230.jpg Use the 2 washers for 2 front bolts since BC has large holes http://i130.photobucket.com/albums/p...o/2ed4892e.jpg Rear ones are ok with using existing bolts. And... You are done. http://i130.photobucket.com/albums/p...o/8a25bae4.jpg Disclaimer: I'm not responsible for any damages on you or your car while following this DYI. Always have a professional shop do the work if you aren't sure on what you are doing. |
wish my pole position had that type of date stamping. mine is just a paper with double-sided tape :suspect: got from gtm as well.
looks great in red! |
that is a pretty seat!
Love that seat, hopefully I'll be able to order myself one next year!
Very nice seat. Thanks for sharing.
Thanks a lot for posting this. I will use this as future reference.
Good post! How do you find headroom compared to stock?
looks really good! About how many inches lower do you think you sit compared to your stock passenger seat?
Originally Posted by eremoy
(Post 21804491)
Originally Posted by clio
(Post 21804487)
