Reduce/Undo Fender Flare
Hey guys. Had my rear fenders rolled by a local that was recommended to me. Turns out he was a monkey that did a terrible job and now I need some advice. Btw, he actually refused to roll my fronts and told me to figure them out myself. I later heard it's because he messed up another s2k pretty bad in the front.
The passenger side actually turned out ok, however for some reason he decided that he would flare out the drivers side. So now I have two issues that my OCD won't let me ignore.
1. The drivers side and passenger side don't match. (Yes I could flare the passenger side to match, but see issue #2)
2. Because he flared it a bit, it does have some waviness to it which bothers me a lot.
Question: Could I use a fender roller in reverse to slightly reduce the flare and maybe smooth out the waviness a bit.
I have never used one so I apologize if this is an idiotic question. I completely understand that it probably won't be perfect. It's hard to tell from this particular photos I happened to have, but it is a pretty minor flare I'm just really picky.. We're probably talking about 1/16"-1/8".
Site Moderator
No. The fender roller really only goes one way and that is folding up and pushing out. Putting the roller on the outside straight on the paint is sure to mess up your paint. You could maybe even it out some but its going to push it out more.
I would take it to a body shop and have them look at it. More than likely they will need to do some hammer and dolly work to get it flat and then touch up the paint.
Site Moderator
You could however you have to heat up the area and with the tape on there is starts melting and can peal the paint up when you go to remove it. I think you could get the roller on the outside as most have enough adjustment to do so but my worry would be messing up the paint by heating the outside of the fender and then rolling over that. Same with tape the roller is going to be pressing the heated tape onto the paint which scares me. The wavyness like I said could be evened out with the roller normally but it may make it look more flared. The key with rolling fenders is taking your time and not trying to do to much to quickly. I don't think what you are talking about is impossible what I am saying is it has even higher risks of a negative outcome.
Real body shop, live with it, overfenders ... unfortunately those are pretty much your choices. At least if he'd have ****ed up your fronts, they'd be replaceable.
I'm in Ottawa as well and looking to roll my fenders later down the line. Mind telling me who you went to so I can avoid going to them to do the work? If you don't feel comfortable calling them out in public do you mind sending me a PM?
krazyaznboy
08-12-2011 12:35 AM
