safety question about installing aftermarket steering wheel
a friend of mine told me to get a full harness if i am going to be replacing the oem steering wheel with a non-airbag one and directed me to this thread: https://forum.miata.net/vb/showthread.php?t=629033
does this 'stitching' apply to our cars as well? and would removing said stitching remedy this potential safety hazard?
i've already ordered the parts (momo wheel, nrg hub and quick release) so would like to get this sorted before i do the install.
Aftermarket wrapped steering wheels are better for safety as they retain the OEM airbag configuration but will cost more. All depends on the purpose of the car.
When I installed my Momo wheel, I also installed one of these seat belt locks to limit movement. I don't know about any stitching.
https://store.windingroad.com/cg-loc...FYYCaQod-5sHcw
If you want to retain the safety of having an airbag I would suggest looking around the forums for Guardian Designs. They are a good [cheaper] alternative to EuroBoutique when it comes to having a customized oem steering wheel. I have had one for going on 2 years with no issue. I had mine wrapped in alcantara.
I recently swapped out my oem belts and seats and saw no such secondary stitching on the oem belts so you should be good to go. That being said, if you do intend to get aftermarket harnesses ensure you use a proper seat with harness holes and a proper harness bar (usually wrapped around a harness bar attached to a roll bar).
