Simple Catch Can Configuration
During the last track session one of the guys behind me came up after the session and asked me if I had mechanical problems.... I guess I'm getting faster and I'm puffing blue smoke in turn 7 @ Road Atlanta.
So, after reading a ton of threads around catch cans, and seeing pictures of all possible combinations of hoses and cans (even some that make no sense...) I decided to go the simplest route and follow robrob's advice.
1) Cap off PCV valve, manifold and intake port:
http://www.amazon.com/gp/product/B00...=AYSI9CNL93O4X
Probably secured with zipties?
2) Bring the hose from the front breather hole and connect it to a catch can that vents to atmosphere:
http://www.amazon.com/gp/product/B00...=A3GBTFY35FDAQ
This is the cheapest can I found that includes a filter which I assume I can use on the second inlet port, since I'm not recirculating the gasses.
Can someone confirm that the links above will work for what I'm trying to do? The car is NA, 90% used at the track.
Thanks!
Thanks!
I would check out the racing and competition forum, there is a sticky there with a DIY to drill your valve cover baffle and it should eliminate alot of your issue, Otherwise you'll just be dumping your catch can frequently and throwing away alot of oil.
Thanks yeah I read about that, but I think on an AP2 it doesn't happen as often, and most of the oil gets sucked from the pcv when open, since it is connected to the manifold. By blocking the PCV there is no sucking, and only very little oil should ever come out of the other hose. I just wanted to try this out before starting to drill stuff..
I'm assuming by your statement you have an AP2.
I did the method where I added a catch in between the valve cover and intake manifold. Yes I'm dumping some oil after a track day but I think I read somewhere that the valve cover needs venting so I opted not to just plug it.
Correct, from my understanding they both relieve pressure for the same area, but one is "active" (pcv) while the other is passive (front breather)
AllStock27
07-10-2005 04:30 PM
