Spoon/Showa shock rebuild
Old 03-02-2019, 10:41 AM
fatjoe10's Avatar
I'm referring to the Spoon/Showa shocks that have the threaded lower perch, not the OEM or Spoon yellow versions. This is for a street car and not bound to any race class restriction.
Old 03-02-2019, 04:24 PM
Car Analogy's Avatar
Received 1,310 Likes on 990 Posts
Then perhaps start a new thread, and not resurrect a 10 year old thread that covers a different topic.
Old 03-02-2019, 09:41 PM
fatjoe10's Avatar
What I described today is what I meant 10 years ago, but I can see I should have worded it better back then.
Old 03-03-2019, 05:24 AM
Hfreak's Avatar
I believe you are referring to a set of dampers like the ones in the photo below, I can't help with a rebuilder but found a pic that helps. Good luck.
Old 03-03-2019, 11:31 AM
fatjoe10's Avatar
These are the correct shocks I'm referring to.. thanks!
Old 03-03-2019, 04:36 PM
Define coilover. Technically, the stock shocks are coilovers. Typically though the term refers to adjustable aftermarket shocks. Typically they are rebuildable as well.
However in this case the shocks appear to have the same nonrebuildable construction as the stock shocks, even though they are adjustable. They do not appear to be able to be disassembled.
Old 03-05-2019, 03:26 PM
B serious's Avatar
Received 1,247 Likes on 944 Posts
OP, have you tried:
-Contacting Opak
-Contacting Showa
-Taking the shocks to a shop that builds motorcycle shocks (lots of motorcycles use Showas).
Are your shocks rebuildable?
10 years?. COT dang, boy.
euroS2K
02-01-2012 10:48 PM
obiwai
04-10-2010 01:30 PM
suzukablueS2000
01-25-2008 11:04 AM
pierceman
01-20-2007 01:49 PM
Quick Reply: Spoon/Showa shock rebuild
