spoon sports 4 point roll cage
I am sorry to be bring this topic up since it has been discussed several times. After extensive searching I have yet to find exactly what i am looking for. I was wondering if anyone who has installed the spoon sports 4 point roll cage could tell me how much i have to move the seat forward. I am 6' 2" tall and don't have much room to work with. Thanks.
http://www.evasivemotorsports.com/Merchant...rollbar_ap1.jpg
http://www.evasivemotorsports.com/Merchant...-XGS-K2S0_2.jpg
one is for the spoon sports 4 point cage the other is for the mugen 4 point. I am interested in both but mainly concerned with is how much i would have to adjust the seat forward for them. thanks.
I have one.
The spoon roll cage is the exact same design as the cusco or saftey 21 4 -pt
The only diffrence is spoon's is steel, cuscos is chromoly.
Obviously steel is stronger.
The seat has to move up about half a foot or less.
I have Bride brix II and that was my situation.
OEM seats you might not have to move them up as much.
Use the search, there are hundreds of pictures of the cages..
your length won't be an issue since im 6.1 and also running a 7pt safety21 cage wich the rear section is an exact copy of the spoon rollbar..
Your seat will be 2-3clicks forwards that forces you to sit up straight and have a better position behind the wheel. this may feel strange in the beginning but you will like the better control you get after driving a few times.
^^ Thanks, ive been searching im not fussed about the seating position as im short, the 7pt you have is the cusco one? does this have a harness bar which you can attach eye bolts? what do you do about the harness down the bottom?
I got a harness bar installed.
i replaced the lower OEM seatbelt bolts with eye bolts so the oem seatbelt is still available and i can hookup the harness belt there too..
I replaced the bolt from the seatbelt click-thingie on the seat with an eye bolt too..
Originally Posted by Gigdy,Nov 30 2009, 06:26 AM
no.
I use it for show until i recieve my bride gias seats.
But to answer the question.. yes it can using eye bolts and a harness bar.
