sway bar effects the height?
does anyone know would sway bar change or effects the height? i just put CR front sway bar on 02, now front gap is lower than the rear about 1 finger, b4 the front is a little little bit higher than the rear. PS: i have Tein S-tech lower springs
If it were bent, it would effect one side. Before you attached it to the control arms, did it rotate freely up and down?
Originally Posted by realblag
(Post 21620424)
i bought it brand new so i don't think it were bent! im not the one who installed it on my car. i paid for the shop to did it, is it still able to correct the height or position? |
i hope they torqued the end link bolts while it was sitting at ride height, but otherwise, a new sway bar should not affect ride height.
darcy |
Affect...
just stopped by my shop and checked my sway bar after the installment...looks everything just fine....seems like it really affect and effect the height lol
i will start looking for CR rear sway bar and gonna install it to see will my rear sit lower than now 2 fingers |
should not affect height at all. the springs determine the height
Originally Posted by ungucpho
(Post 21621557)
im kinda confused :argh: so it's might not about my sway bar affection. isn't it? recently i had changed those Front end tie rod(oem) on both side second i did re-alignment my car then i added Sway bar do you think is bcoz of end tie rod or any possibility? by the way i live in CA san jose....any good shop around here that i could bring my car to let em' take a look and fix Please |
Originally Posted by acn684
(Post 21621223)
Affect...
I'm confused, what are you trying to accomplish?
