Tanabe Touring Medalion Gasket Sizes
I picked up a used Touring Medalion and wasn't sure what gasket sizes i should order. I need the one from the resonator to the split pipe and from the split pipe to the 2 mufflers. Are they all 60mm or is the split 60mm and the 2 mufflers 50mm? Thanks in advance.
I use a Vibrant 1456 between the resonator and the Y-pipe and two Vibrant 1455s between the mufflers and the Y-pipe.
Sorry to resurrect an old thread. But I bought one new and I'm not sure but I thought all three gaskets were the same diameter and now I'm wondering if the one after the resonator is restrictive? Anyone bought one new?
2x 50mm<for rear>after Y pipe
1x 60mm needed for after center box>at Y pipe
I just replaced mine.
same size as oem but oem is crushed 50mm pipes at Y
Ah so your set came with 3 different sized oval ones for the inlet (60mm) and two outlets (50mm)? I'm pretty sure all three of those were the same in my box, and I'm wondering if they were all 60mm diameter and the outlets on the Y pipe just have flanges that accommodate? I'm wondering if I gotta get under there to check the Y pipe inlet to see if it's at least 60mm
05TurboS2k
07-24-2008 03:36 PM
