View Poll Results: what size test pipe
70 mm
42.86%
63
57.14%
Voters: 14. You may not vote on this poll
test pipe
hi guys if i want to install a test pipe should i get the 70 MM or the 63 mm i have a stock exhaust will both work?
another question do i need to also buy the air pump delete
how bad will it smell
one more thing are there any test pipes that have built in tabs for the heatshield
I believe this question was answered at least once in your other queries. Answers ain't gonna change by asking again.
Abrupt changes in exhaust diameter disrupt the flow and can cause performance disabling pulses in the exhaust. Header is 57mm ID so a 70mm exhaust will be less effective than one closer like the 63.5mm version. A "test pipe" is, of course, irresponsible and achieves barely measurable gain over a high flow cat. Not seen any with tabs, hence the need to weld them on mine. You've seen the photos of my Berk high flow cat.
-- Chuck
-- Chuck
Just adding a 60mm test pipe gives a big increase with no other mods. The OEM cat is quite restrictive and from what I have seen, I have yet to hear of a stock car making the claimed standard power out put. On this particular dyno, mine was even up on other cars.
Before test pipe:
After test pipe:
Before test pipe:
After test pipe:
