Trunk Bulb And Dome light bulb size
Old 01-05-2011, 12:52 AM
molotovsoldier's Avatar
Default Trunk Bulb And Dome light bulb size
Hey everyone! Im planning on replacing my stock trunk bulb and map dome light bulbs to leds anyone know what size bulbs these are? Are the T10 Led compatible with the Trunk Light and License plate light? also what size bulb is the dome light? I want to use LED lighting for my dome light. Your help is appreciated and thanks.
Old 01-05-2011, 01:20 AM
TRD_Celica's Avatar
License plate light and trunk = 168
Dome = 3022
SMD>LED
Old 01-05-2011, 02:58 AM
ahrmike's Avatar
I went to oznium.com, picked up a superslim LED strip that fit into the dome light area. comes with bayonet fittings.
I used one bayonet fitting to power the dome and I wired the empty side to a series of LEDs I installed into the footwell area. Works pretty great...but I chose GREEN which was a bad idea. Its so damn bright I cant leave it on in fears people will think I'm a ricer..haha
Old 01-05-2011, 07:51 PM
wisdom's Avatar
The dome light is a festoon. So any SMD LED festoon bulb around 30MM should work. Trunk light is a 168, and its interchangeable with many types of SMD LEDs.
Old 01-06-2011, 06:13 AM
takeshi's Avatar
Originally Posted by TRD_Celica,Jan 5 2011, 02:20 AM
SMD>LED
Support?
My LED board lights have 6 high intensity LED's each. No SMD can provide the same, even coverage.
Old 01-06-2011, 04:44 PM
ahrmike's Avatar
http://www.oznium.com/led-dome
^Bought the 1.5x5.
also bought flex LED strips for the bottom, as I said earlier. Trust me, if youre willing to spend $25...you will NOT find a brighter bad-ass light.
badboy00z
07-25-2014 08:00 AM
ilaggoodish
07-01-2009 01:17 PM
w0rdie
05-12-2007 10:56 AM
S2002
11-04-2006 08:10 PM
Quick Reply: Trunk Bulb And Dome light bulb size
