Two Questions on Seat Heaters
Hi all,
I have two questions on adding seat heaters: 1. Can anyone recommend seat heaters that would fit the S2000 seats? Most of what I'm finding is 11" or wider, and most can't be trimmed width-wise (length-wise is usually OK, depending on type). I think 11" is too wide to effectively fit into the seat. Most of the links from past discussions are dead or no longer valid (threads are dated). 2. I have Clazzio covers, and my factory leather is somewhat hammered. Is there an issue putting the heaters between the factory leather and the Clazzio covers? Or should I pull the factory cover and put it under that, even though my Clazzio's are "permanent"? If they can go between, I think #1 may be mitigated using 11" width... but if not, I definitely need slimmer heaters. Thanks! |
Thanks, @theprophet36. I was looking at those but concerned about the size, since they are 11 3/4". The seat bottom and seat back (minus bolsters) is a little less than 11". I do have stock seats - just with Clazzio covers on them.
