Wich springs should I use?
Originally Posted by Hockey,Nov 25 2007, 03:28 AM
Thanx. I've done almost 2 dozen cars now across the SoCal region.
You make the OEMs look like $$$$ aftermarket
I have been on RS*R TI 2000 springs for a few years now. The springs are made to work with the OEM shock. The ride is near stock handling is pretty much the same to me and the look is great, 1
the better question is what are you going to do with your car and will you get damper for it.
forget half of the spring out there if you are using stock damper, for example eslpeir is coupld hundred lb over the stock rate, good luck using that on stock spring.
