***Official ITBs Thread***
#512
Member
Yep, hoping I can do some testing on the dyno with filters / mesh / plenum on and off. There's too much misinformation about using them on here and what does / doesnt lose power.
#513
#514
I was wondering the same thing but I think it's made specifically for the S2000 so would think it should fit?
http://www.jsracing.co.jp/js2/index....B-S1&xKEYWORD=
Are you getting the complete snorkel setup as well MB?
Seems that it has got a separate filter.
#516
#517
MB has a RHD car correct? That should be a really nice solution for him if so.
#518
I think it's pretty much common sense stuff, like if the air filter is enough of a distance away from the mouth of the velocity stack then you don't experience any HP losses. It seems most people who report HP losses were putting filters or screens right at the opening of the velovity stacks and were disrupting the airflow right as it entered the stack.
#519
Yes having enough clear air around the mouths is crucial.
Here is some info from ITG:
ITG recommend fitting the tallest element possible, though a gap of 1/2”(13mm)average must be left over the top of the filter for air to circulate.
If using ram pipes there must be an absolute minimum gap of 3/4”(19mm) or preferably 11/4”(32mm) between the end of the pipe and the underside
of the top of the filter.
#520
Member
It fits fine. Mine is RHD. I checked it out when I was at J's Racing earlier this year on their Time Attack car. It's using Toda ITBs too.
I might go for the rest of the intake. It's expensive but it's very very well designed. So I have that option, or the option of just using the Toda mesh screens and a big duct from the front of the car as per pic below. J's TA car now just uses their airbox and a custom duct, and they said it's unfiltered but I suspect they have mesh covers. I will check with the guy I know. Different requirements for TA versus racing though.
The J's full intake option is probably better as it offers better protection and means the ITBs are completely open. The mesh option does create some reduction in flow right at the inlet and speaking to Toda Japan, they estimate 10bhp loss versus using a filter further away like the J's Racing setup. I've probably talked myself into the J's Racing option but it will mean relocating my oil cooler and the duct gets in the way of my bonnet aero catches so I'd probably need a new one
