***Official ITBs Thread***
#801
You could use an ohm meter and measure the TPS while slowly turning it, sensor obviously needs to be disconnected.
If the resistance is nice and linear the problem should be somewhere else, normal range should be around 0.5-4.5kohm.
But it's probably a ground problem like the tuner suggests.
Check the wiring schematics, it looks like ecu connector C and pin 18, 27 and 28 is end of the line from the TPS.
Check for continuity between these point and also that there is no short to ground.
It's also a good idea to have someone wiggle the wire harness at the same time to force any intermediate faults to show.
#806
RHD Engineering | How to synchronize ITB’s
Or is there a better one?
#808
Yes that text seems good. I did a video I while back when I adjusted mine.
http://www.youtube.com/watch?v=YcUxIlEqHt0
#809
Blown Head Gasket
So, my head gasket blew. I am pretty sure it was caused by heat. I was still doing datalogging for the start tune and had noticed several instances of 200 plus temperatures on the AEM software. I assumed it was the calibration. I am now to the point of either stroking the motor or swapping to an LS or K24. This sucks and I leave the country in 75 days, so I am on a schedule to get this thing up to be shipped
#810
I don't want to blow another head gasket, so i am trying to figure out the best way to bleed the coolant next time. There is a nipple on the Hayward system, but I have hooked no coolant lines to the ITBs. So...is that the purposed of the circled plug on the attached picture.
