S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
3" or 4" cai
Old 01-15-2018, 01:18 PM
  #261
arsenal's Avatar
Originally Posted by sirbikealot7
I used one of these from vibrant Vibrant Performance ::.
Brilliant thank you.
Do you know what sizes are needed for the front VC vent and for the air pump?
Old 01-16-2018, 09:13 AM
  #262
sirbikealot7's Avatar
I deleted my air pump. I think I used the 19mm one and hadn’t to put the hose end on boil wing water to get it maleable enough to stretch over the fitting.
Old 01-16-2018, 12:06 PM
  #263
flanders's Avatar
Valve cover vent is half inch, not sure about the air pump hose but it's bigger.
Old 01-16-2018, 12:29 PM
  #264
arsenal's Avatar
Thanks Flanders.
There seems to be conflicting info regarding the front VC vent. Under load, is:
1. air being sucked into the valve cover through the front VC vent, from the intake tract?
2. air being sucked from the valve cover from the front VC vent by the intake tube?
If it is number 2, and a catch can is put in place and vented to atmosphere, there is no longer any vacuum from the intake to pull the air out from the VC. Is this detrimental to the engine?
Old 01-16-2018, 02:49 PM
  #265
Air goes from the vent, to the the intake. If you put a vented catch can there, it wont hurt anything, cap or delete the fitting on the intake and leave the valve cover vented, you'll collect very little oil there. Most of it will come from the PCV port.
Old 01-16-2018, 06:06 PM
  #266
arsenal's Avatar
That's what I figured. Does the amount of the vacuum from the intake actually suck more air than the valve cover puts out by itself? i.e. is the intake sucking more air than the vent can blow.
Old 01-16-2018, 10:21 PM
  #267
flanders's Avatar
The intake sucking is going to help remove any positive crank case pressure, is it needed? Not really but all small things ads up in the end.
Old 01-23-2018, 08:57 AM
  #268
arsenal's Avatar
Just received my intake.
Should be able to get it ready so that I'll be able to do a baseline dyno on a bone stock AP1, then remove the intake and put in the 3.5" to 4" intake on the dyno and see the gains (hopefully!) or losses next week or so. Just need the Izze thing to come in and do the coolant bypass to make sure I can take it on and off in time on the dyno.
Old 02-01-2018, 02:45 PM
  #269
arsenal's Avatar
Dyno time is booked for tomorrow afternoon and fortunately the shop is allowing me to make changes on the dyno within the hour.
I'll be able to provide numbers for the following:
1. Baseline stock AP1
2. Throttle body to 3.5" to 3.5" about 18" pipe for each section with one 90* bend. Places filter in the OEM location
3. Throttle body to 3.5" to 4" about 18" pipe for each section with one 90* bend. Places filter in the OEM location
4. If time permits, 3.5" to 3.5" to 4" 18" pipe for each section with two 90* bends, places filter in the fender well - not keen on this as I am in the PNW where it rains. Alot. And it would take a while to get it fitted - may be able to try it with the filter hanging out somewhere
No tuning will be done, but hopefully I make some power!
Old 02-02-2018, 09:10 AM
  #270
s2000Junky's Avatar
3/4"
Quick Reply: 3" or 4" cai
