3" or 4" cai
#42
#43
Not that it really matters but for fun I ran my friends turbo gsr from a 20 roll and beat it by a car and a half. It made 270whp that day, he spun down low and wasn't able to real me in
#44
#45
that short conical reducer at your TB is likely creating a good bit of turbulence. Consider a longer conical reducer to smooth out the air flow. Is the inlet of the TB radiused at all? Is there value in a velocity stack right on the TB inside the 4" pipe? (hmm, I may need to try building this. Anybody builds this, I want royalties ).
#46
That's the only reducer I could find I'm going to look into getting an aluminum one made. I could technically make one out of sheet metal but I'd have a seam. I have another throttle body I'm going to port. As for the velocity stack, it's too small of a difference to fit on in. If it was a 5 or 6" intake it would work.
#47
I doubt we have room for a 6" pipe but if we did then something like this would work.
http://s188.photobucket.com/albums/z...ndsintake2.jpg
That's 3.5" off the T/B to a 6" velocity stack and then 6" from there to the filter. That 6" 90* bend use to feed a 855 c.i. engine.
ROD
ROD
#48
Banned
the longer the pipe is the less a velocity stack at the opening matters. If the pipe is very short a stack will help a great deal, but with a long intake the length of the intake serves to smooth out the air flow. On my long intakes, there is usually no difference between a good air filter and a velocity stack on the dyno.
#49
Can't wait to finish my exhaust an et this thing tuned! Messed around with my friends 190whp integra last night, pulled him from a roll by half a car. He shut down at about 80 because I was pulling more.
#50
I'm thinking about doing a 4 inch into a 3.5 inch or just 4 inch all the way. I currently have a aem v2 intake with a 80 mm throttle body and port match intake manifold. I currently put down about 235 whp. What do you guys think?
