Aftermarket cams reliability
#22
If anyone is looking for some billet Inline Pro cams I have some for sale.
Stage 2
Intake
Lift: .500" (12.70mm)
Duration@.050": 265°
Exhaust
Lift: .490" (12.44mm)
Duration@.050": 255
Stage 2
Intake
Exhaust
Duration@.050": 255
#23
One thing that must be considered as well, vale train noise will also be affected. My 04 S2k was much louder with Schrick Cams installed. For me it was way too loud but the cams made power on a stock valvetrain. I removed the cams because of the loud valve ticking.
#24
Despite the noise do you think it was doing harm to the motor or do you think if you let the cams sit in there, everything would be ok?
#25
Has anyone plastic-gauged the bearing clearances on the aftermarket vs. OEM cams? I wonder if the aftermarket cams journals might be on the large side of tolerance. There's no oiling passages in the cams, so that can't be an issue. Is there any difference in the wear if aftermarket or OEM springs are used?
The only things I can seem to think of is maybe the cam journals are not sized exactly right Or maybe the extra lift puts too much load on the bearings and pushed the cam into the bearings, breaking down the oil film.
I have NEVER seen this kind of wear in the cam bearing on any engine, and I've probably had over a thousand engines apart. I've occasionally seen cam lobes fail, seen lots of rod bearings fail, spun main bearings, but never anything like this.
Can the cam bearings be bored out and bearing shells inserted?
#26
BC cams.
But i I was running supertech dual valve springs. Can't remember spring seat pressure but it was higher than stock. Chris ran across a thread from several years ago suggesting to run oem or lighter springs if you are going aftermarket cams. Maybe he will link it. I am spitballing here but could higher valve springs attribute to this accelerated wear?
This motor eventually died from breaking a valve cap off of the stem on cyl 4 exhaust. Cams were removed prior to valve failure.
#27
BC cams.
I just dont see the need for aggressive dual springs but in the most modified of builds, and that doesn't mean longevity will be improved, it just means better control of valve float for the application/performance. Seems to me, using the lightest spring required to control valve float at a particular rpm should be the goal. I understand that some aftermarket retainers/keepers or valves require a dual spring to be compatible, but with enough reports of cracked/chipped ti retainers etc, I question if any of the performance gained is worth sacrificing reliability and longevity over oem. Underlying all this I think matching the components is important, so there probably should be a clear tested chart for proper valve spring weight per the aftermarket cams being used and what retainers/keepers are compatible with that spring weight. Guessing probably isn't the best option here, when you can see what the bad results can be. Im thinking if any doubt or lack of information, that airing on the side of less spring tension/oem is better then too much.
#28
I removed the cams from my oil analysis telling me something was wrong. The cams were the only thing I changed. Since it was aluminum in the oil I went to the head first and these are what I found. Most can catch a finger nail on the grooves.
My buddy has had a theory that I don't agree with but I'll put it up. He thinks the supertech dual springs were the cause since they have more pressure than stock or even the beehives. I call bologna but it's out of my expertise.
My theory is the cam oil journals weren't perfectly round or the tolerances were greater than stock.
I did it as a safety net for my sloppy shifting. It should hopefully save me from minor over revs...
#29
Could this be from not using an assembly lube when fitting the new cams? When I look at the image the center of all the caps appear to be in pristine condition and the outside edges are rough/abused. The cam bearings are oiled from the center of the journal, so where the cam was for sure seeing oil pressure it is fine. If the spring pressure was too much and the pressure the spring was placing on the cam was enough to break the oil film down would it not make the same damage across the whole bearing? The oil film would have to be squeezed out somewhere.
#30
The oil channel just hasn't been worn through even with the rest of the surface yet it looks like. I don't see normal discoloration from heat where lack of oil is the culprit. At the same time, I would think two surfaces where a lot of pressure/friction was present would show a similar heat discoloration cutting through oil film. This almost would seem like the surfaces had too much play so the cams were lose? Maybe it was a combination of added spring pressure with not the right trq spec on the cam tree carrier bolts.
