Any official Oil Cooler thread?
Originally Posted by conanius
Sorry to sound stupid, but why would you wantto keep the oil cool bar reducing change intervals... Does it improve engine output also ?
Originally Posted by Sobe Death
Did you have to install an inline pump or does it use the engines oil pressure?
I heard it has been good for some years
The price is steep but it seems like the obvious choice in that price range unless you can afford an ASM kit for a few grand which is totally dumb unless your car runs strictly track.
Originally Posted by Stealth Operator,Apr 27 2010, 09:38 PM
But an oil cooler does stop you from losing power. Once the oil temperature reaches over 130 celcius, you no doubt will start losing power or not make power, making the car sluggish and slow.
High temps in the combustion chamber is great for power as long as it doesn't cause detonation. Hot oil is thinner, so pumping losses will go down, and higher temps in the combustion chamber means there will be more heat pushing down on the pistons. If your oil or coolant is colder than it needs to be, then you are giving away power.
Originally Posted by CapoArgentino,Apr 29 2010, 03:35 PM
^^ Thats why over cooling is bad and kits w/o a thermostat should be avoided, at least in DD apps.
It's all good
The thermostat for the oil cooler is meant to prevent overcooling. You don't want oil passing through it's radiator all the time, only when a certain temp is reached. Same exact concept as the coolant system. On a track only setup, you might be able to get away with a kit w/o thermostat since you wont allow the oil to cool down sufficiently during a session until you stop.
