AP1 AEM Tune - very low output after tune, 125kw
Hit reply too quickly... My other thought is that it shouldn't matter if its 5th or 6th as they are both overdriven.
I am going to see if I can get a reading of both the factory and AEM ECU runs overlaid to see where the power is being found.
I will post the dyno sheet tomorrow once I get the car back.
What kind of dyno is being used?
Can't really see any reason why only 6th would be used, this and the low result kind of questions the tuners knowledge as well as any real engine problem.
You should really get that dyno plot posted here since that tells way more than just one number without even a rpm point.
HawkeyeGeoff (02-28-2018)
I don't see why it should be run in 4th? If anything, it should be 5th (4th: 1.161 5th: 0.970), I'd run out of 4th gear with my 4.77 FD which my tuner is aware of.
It's a Dynapack dyno as stated in the OP.
Will post dyno plots here later today once I get the car back.
Run it in 5th. 6th makes no sense. Not like your going to have traction issue on the roller at your power level and gearing.
Remember he has 4.77. I don't think he could run the car up to redline with them, also with 180kmh limiter. It has to be 4th if I'm not mistaken. How are you adjusting the speedo for the gear offset?
I am putting in a Modifry yellow box which is ready to go in. Remember this is a hub dyno so the dynometer is bolted straight to my hubs.
Dyno sheet as promised.
A few things I want to clarify:
The dyno is definitely not the issue here nor the tuner - he had a AP1 similar to mine in NA which did 158kw only last week.
If you have any specific questions you'd like me to pass on, I can do that too.
- The tuner is probably the best in my area, arguably in my country with a few exceptions but they're in another city and its a pain to go back and forth to a city 8 hours away.
- He spent considerable time running it up in 4th and 6th to check the differences. In 4th, it spun 144.3kw before running out of gear.
- His first recommendation to me was to check if the motor has been accidentally decompressed and to recheck the timing.
