AP1 AEM Tune - very low output after tune, 125kw
#33
Quick update to thread - retune booked for 20th.
The exhaust valves were very tight and all four cylinders needed to be adjusted back to spec. Intake side were all fine.
Compression was 245 psi all four cylinders the same gauge that read the 225/225/225/220 in the same day.
Looking forward to the results in a few weeks.
#35
Update from re-tune - still low on power. Compression and timing is correct now - 250 psi all 4 cylinders on another set of gauges.
The car made 140kw (187hp) in 5th gear and 136kw (182hp) in 6th. Tune was only adjusted about 1-2% across the board.
Where should I be looking next?
Dyno pic
Dyno pic
#36
Verify ignition timing with a timing light if you haven’t already. Same thing happened to me. Was expecting higher power from the engine only to be disappointed. My ignition timing was off by 15-16 degrees retarded. Weird thing was it had been calibrated before. It somehow defaulted back to the 5 degrees btdc. Still waiting to tune mine.
#37
Dyno pic
Dyno pic
mcopley
86
05-27-2013 09:39 PM
