S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
AP2 V2 manifold TB inlet bore limit
Old 04-15-2018, 02:44 PM
AP2SSM's Avatar
Default AP2 V2 manifold TB inlet bore limit
Hey guys, I don't really like asking simple question such as this but I could not, to save my life, find an answer online. What is the max bore size you can bore, on the OEM AP2 V2 intake manifold? Looks like you can go bigger than you could on the AP1 intake manifolds.
Old 04-15-2018, 03:47 PM
AP2SSM's Avatar
Also....I am wanting to find out if the bolt pattern on the TB is the same as say the RBC manifold. I want to install the V2 manifold with an adapter to run a larger TB preferably a Ktuned 72mm or maybe some 74mm. I cannot find any info to confirm this would work.
Old 04-20-2018, 05:15 PM
ConeKiller2's Avatar
I have a v2 manifold that is bored and has the adapter to use the bigger tb as you want to run it. The v2 manifold has a larger plenum which will pick up more power. $150 shipped. Let me know
Old 04-21-2018, 09:47 AM
s2000Junky's Avatar
V2? You mean the factory DBW manifold?
Old 04-23-2018, 05:14 PM
AP2SSM's Avatar
Yup I mean the DBW one. I am hoping I could run the ktuned 72mm TB which already has the provision for the IACV.
Old 04-23-2018, 08:32 PM
s2000Junky's Avatar
Ok, well I haven't sized one up lately, but based on the stock bore size of the DBW TB opening in the manifold being 68mm and not having provision for the water port like the 00-05 do taking up space, I would be surprised if you couldn't bore out at least 72mm and likely a fair bit more.
rfsinopo
06-20-2018 11:41 PM
liquidgsr
08-14-2012 05:48 AM
Soul Coughing
12-14-2009 02:04 PM
grantedS2k
07-12-2006 12:06 AM
villain2000
12-16-2004 08:52 PM
Quick Reply: AP2 V2 manifold TB inlet bore limit
