AP2 V2 manifold TB inlet bore limit
Hey guys, I don't really like asking simple question such as this but I could not, to save my life, find an answer online. What is the max bore size you can bore, on the OEM AP2 V2 intake manifold? Looks like you can go bigger than you could on the AP1 intake manifolds.
Also....I am wanting to find out if the bolt pattern on the TB is the same as say the RBC manifold. I want to install the V2 manifold with an adapter to run a larger TB preferably a Ktuned 72mm or maybe some 74mm. I cannot find any info to confirm this would work.
I have a v2 manifold that is bored and has the adapter to use the bigger tb as you want to run it. The v2 manifold has a larger plenum which will pick up more power. $150 shipped. Let me know
V2? You mean the factory DBW manifold?
Originally Posted by s2000Junky
(Post 24449321)
Originally Posted by AP2SSM
(Post 24450274)
Yup I mean the DBW one. I am hoping I could run the ktuned 72mm TB which already has the provision for the IACV.
