S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Berk 3" Exhaust Problem
Old 11-14-2013, 10:13 PM
Member
OVER 9000!'s Avatar
Default Berk 3" Exhaust Problem
Alright, I have had two issues with my Berk 3" exhaust and just wanted to see if anyone else has had similar problems.
The first issue is that the sound deadening material in the muffler has deteriorated and sounds like a bunch of sand is in the muffler when you tilt the exhaust (when I had it off of the car).
The second issue is that it only has 1/4" to 1/2" of space between the exhaust and the nuts and bolts that connect the axles to the arms. That is with the ap2 hangers being used. The exhaust has made contact with these bolts and put some scrapes and a good sized dent in the exhaust. Thankfully it did not punch a hole through the metal though.
So have any of you experienced these problems with your Berk? I know that its normal for exhausts to burn up their sound deadening material, but this sounded like there was a good amount in there shifting around whenever I moved it, so that's why I brought it up.
OVER 9000! is offline
Old 11-15-2013, 05:48 AM
s2000ellier's Avatar
I have had both problems you speak of. The closeness to the axles can be cured with using the AP2 hangers in the right spot. For me I used the long side of the AP2 hanger at the mount point closes to where it connects to the header. The 2nd AP2 hanger I used at tip of the muffler to clear the bumper.
s2000ellier is offline
Old 11-15-2013, 08:28 AM
Redline S2K's Avatar
I had the hanger issue but no problem with my muffler. I played around with the mounts and now my exhaust sits close to the axle bolt but doesn't touch. Also, with the right mount positioning, the exhaust shouldn't move a lot. Mine moves some but not enough to contact that bolt.
Redline S2K is offline
Old 11-15-2013, 12:01 PM
Member
OVER 9000!'s Avatar
Hmm I guess I'll take a look and see where I have the ap2 hangers mounted up at.
Old 11-16-2013, 09:52 AM
mugen_rsx09's Avatar
I had the same problem with my axle grinding against my exhaust. Especially in the rain -_-
mugen_rsx09 is offline
Old 11-16-2013, 05:31 PM
Email Berk and they might replace the muffler for you. That's what they did when my buddy was having issues with his Berk 3".
s2000maniac is offline
Old 11-17-2013, 11:06 AM
As for the hangers, it's all about getting them the right way. I originally had this problem, and after I adjusted one of the 3 point hangers (which was the front most one on the cat-back part) to be the long side, I have had 0 clanks or issues. It gives another 1/4" clearance, which is all it needs.
s2kreeper is offline
Old 11-17-2013, 03:10 PM
never have had any issues with my berks setup yet
sleeper15 is offline
Old 11-18-2013, 05:26 PM
Another problem I now have is that there is a crack on the HFC that wraps around 3/4 of the exhaust. I have a check engine light and my car smells like gas. Im upset that it is no longer covered, I've had it for 1 year and 3 months
Old 11-19-2013, 09:34 AM
Kermdaddy's Avatar
OEM cats are covered for 8 years or 80,000 miles. I doubt that will help your argument, but who knows.
Kermdaddy is offline
Quick Reply: Berk 3" Exhaust Problem
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
