Berk 70mm HFC untuned
I'm prepping for this year and I was interested in using a Berk 70mm HFC to drop weight and still be STR legal. I've reviewed a ton of information about a tune afterwards but I haven't seen anything about using one untuned. I was planning on a PLM header and tune later this year or early next year. Would there be any adverse effects like a compromised torque curve or compromised AFR that could pop a motor? My car is relatively low key as it sits. K&N FIPK and a berk single catback for weight savings.
Car is a 2005.
Any thoughts welcome!
-Maniac
Car is a 2005.
-Maniac
Not starting a fight but other than subjective reasoning I can't draw a conclusion.
Is there definitive proof of that? I couldn't find anything substantive to solidify that statement. Is there a flow rate chart between the two? What materials are used to verify the claim of higher quality? Why use the 63mm and not the 70mm?
- The Berk HFC have problems with their catalysts braking loose or falling apart, mainly with boosted cars. The EVS uses a Magnaflow catalyst that shouldn't do this, similar to the Rockstar Garage HFC.
- The welds and materials are better on the EVS HFC.
- I remember reading a few members on here have noticed a louder exhaust and more rotten eggs smell with EVS cat installed compared to Berk HFC, which means a higher flow rate. I noticed this when switching from a random technology 63mm HFC and also gained about 5HP on a dyno with the EVS 63mm HFC. I should mention that my car has a Vortech Supercharger @ 7psi too.
- I went with the EVS 63mm HFC because I have the AP1 Mugen header/exhaust which is 60mm, you want to match/come close to the piping of the rest of your exhaust.
__________________
My For Sale Thread: JDM and OEM parts
I don't know about EVS but Berk definitely use Magnaflow cores, the part number is even stamped on them.
Just get the cheapest one, I highly doubt there is any real performance difference between them.
I remember 2 cases from germany were the berl hfc died on track.
The first one was on a track s2k. After one round on the Nürburgring the core broke loose.
The other on was supercharged. This time the core broke also loose but looked like most combs were melted.
The EVS one looks better but don't know if it's really better in theses scenarios then the berk.
I had the Berk a few years ago and now the EVS. The EVS will go for the TODA resonated test pipe.
Based on my research and experience:
I know little about exhaust flow but I'm convinced changes in pipe diameter can induce harmonics in the system and reduce flow. The OEM system is a nominal 60mm.
Header exit is 57mm so I've stuck with that diameter to the tail pipe including a 63.5mm Berk high flow header. FlashPro tuned on Shell 93 shows 221 hp at the rear wheels on a Mustang Dyno which I'm told produces conservative power numbers.
-- Chuck
-- Chuck
