S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
best fitting test pipe?
Old 03-14-2017, 12:57 PM
TofuProductions's Avatar
No issue with my 63.5 Berk.
Old 03-14-2017, 08:25 PM
DrJimmyV's Avatar
No issue with my 63mm from 1320/ebay.
Old 03-14-2017, 10:02 PM
Singh_snisen's Avatar
Berk products are very reputable. Check everything and ur after market exhaust. If anything you can send pics to Berk and I'm sure they will help u out.
Old 03-14-2017, 10:47 PM
S2000_916's Avatar
https://www.s2ki.com/forums/s2000-un.../#post23741199
this guy has exact same issues with pictures
Old 03-14-2017, 10:50 PM
S2000_916's Avatar
Old 03-15-2017, 08:57 AM
Those bends look quite a bit off..
Old 03-18-2017, 08:04 PM
SilliG's Avatar
I had a similar problem with a eBay test pipe. Switched to Invidia bolted up perfectly
Old 03-21-2017, 04:57 AM
Zivman's Avatar
I just installed a 63 berk TP. no fitment issues bought from ballade via ebay.
Looking the pic above, a few things seem off. the o2 bung seems to be a two part setup. Mine definitely didn't look like the a bung was welded to an extension pipe. Secondly, I never noticed any bend/clamp marks on the pipe like are seen above
Old 03-21-2017, 09:45 AM
Site Moderator
Manga_Spawn's Avatar
I have owned several berk test pipes and they have always fit right. Invidia is junk. Had one of those and the cel fix didn't work at all.
Old 03-21-2017, 11:31 AM
GoKaart's Avatar
I use the Berk 63.5mm test pipe with my HKS Hi Power and had no issues. The CEL fix works perfectly.
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Berk Technology Cat Delete Pipe - 63.5mm - Honda S2000 00+
Quick Reply: best fitting test pipe?
