Originally Posted by K20iVTEC
(Post 24119651)
Don't get me wrong, this is a beautiful build but why not just stroke the f20 with a k24 crank? You would get the same numbers at a fraction of the cost...
Nice. This is a project I want to tackle down the road. For the reasons you listed and mainly because I'm looking for a big project. Do you plan on seeing any track time with this car?
People get really upset over this engine swap for some reason. :confused: |
Do you have AC?
Originally Posted by freezingcoffee
(Post 24120067)
Do you have AC?
Originally Posted by b.r.i.a.n.
(Post 24119699)
It looks like the tuner was very conservative with the cam timing to say the least. Your typical K series will have a nice fat hump in the middle from the cam timing. I tuned a similar engine with 11:1 compression ratio pistons and cams a few years ago.
http://farm9.staticflickr.com/8226/8...5b44536e_c.jpg **150,000 miles, 6yrs+ l8r...Le Build. (k24/20, hasport, buddy club, etc.) - 8th Generation Honda Civic Forum Notice the hump in the middle and the peak torque coming in around 6k. Here's another example: http://i154.photobucket.com/albums/s.../crowerk24.jpg Mmmm Power! K24 8400RPM All Motor Dyno !!! - Club RSX Message Board That's a stock block k24a2 with the same brian crower stage 2 cams. Again, notice the hump you see on your typical K series. You should be seeing a lot more mid range hp. |
Originally Posted by blueprint
(Post 24120766)
My tuner very well could be erring on the side of caution... It's hard to gauge how other K24a2's perform when there isn't much information out there on one swapped into an S2000.
Originally Posted by s2000Junky
(Post 24120776)
Yeah, it does look like its starving for something about 5k rpm. The power kicks pretty good still about 5700rpm so I don't know if its just a matter of ignition timing and fuel, or cam timing/transition, but your clearly leaving free power on the table.
(Post 24120766)
I'll be joining in this spring. -08 k24a2 bottom end -type s head -ballade header -custom RBC mani w/ 74mm TB -rdx injectors -3.5" cold air intake and maybe some BC stg 2 depending on what my tuner says |
Originally Posted by decepticondc5
(Post 24120963)
thanks for sharing. i'm looking to complete mine hopefully this time next year.
ciuld you elaborate on the pulleys and belt used? is ps/ac remaining? |
