blueprint's K24 Powered S2000
#33
Just curious, whats the main reason behind this swap? Sure you might make 30 tq over a f22 in the midrange but with peak numbers being damn near identical i dont feel its worth $15-20k on this swap unless theres something else real obvious that im not seeing. I mean kudos to you for getting the swap done but wheres the big benefit?
#34
Unless I'm reading the dyno wrong it's showing 251hp to the wheels, which is quite a bit more than a F22.
Droid (05-10-2019)
#35
Except the OP isn't making a killing in the mid range here either. It looks to be making pretty much a stock vtec F series power curve, just a bit more power throughout. About 20trq/whp over a Standard bolt on F22. Not to knock all the hard work here, but yeah I'm pretty much in the why bother camp myself. But I have always been thrifty with my money with this car, trying to get the most for the least. This build flies in the face of that in every way. To each their own as they say.
#36
im just saying there are means to gain just as much with the stock platform for far less. But if he did it just for the sake of having a k series in the s2000 then my curiosity ends right there.
#37
I always wondered how these would do supercharged as in root style. Heck, just get your basic k swap kit and a stock k24 and supercharge it. Should make a shit ton of mid range without building the motor.
kswap kit as stated above-3k
k24 long block-1k give or take
root style supercharger jackson/comptech-2k?
Another positive is the supercharger will keep the perfect balance compared to a Sos/vortech f series supercharger. Blow the motor? No problem, grab another stock k24
#38
Mod for mod the K series just offers so much more potential in NA form. Additionally the K series has i-VTEC which allows a variable intake/exhaust valve overlap.
This configurability allows the engine to respond to modification much better. To greatly simplify it, it allows the engine to make both high top end power and low end torque by varying the amount of valve overlap based on RPM & Load.
In the end the decision for me was simple. The potential, engine availability, cost of replacement engines and the endless aftermarket support. They all played key factors in my decision to swap this engine in. I am very happy with how the car performs.
#39
#40
