S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Brian Crower Stage 2 Cams on an AP1
Old 11-27-2013, 04:39 AM
s2k-jn's Avatar
Recieved 0 Likes on 0 Posts
Default Brian Crower Stage 2 Cams on an AP1
Just bought these bad boys and was told they could deliver up to 15kW gain with the right ECU and tune, what're your thoughts?
Also is additional parts needed to install these?
s2k-jn is offline
Old 12-05-2013, 07:28 PM
im about to do the same set up, in order to run these cams you will need to upgrade your valve trains and heavy duty TCT in order to get out best the performance and reliability for the motor. a proper ems is recommended. There is a huge thread about these cams, check out Real Street Performance's s2000 result for these cams!
jchan727 is offline
Old 12-06-2013, 02:24 AM
hi ! im going with the same setup , and people of real street says to me that the taiming chain tensioner doesnt have to change. its allright with oem!
Nik2k is offline
Old 12-07-2013, 06:19 PM
wildweSt2K_93's Avatar
Looking into these same cams as well. And a full ITB setup in the future. I was wondering about the TCT as well but my guy At hippo performance told me the same as REAL street. The oem TCT is fine that when it starts to make the slightest noise have it taken out and cleaned well and you should be GTG. My goal with cams, velve springs, retainers, and TB + CAI and 70mm exhaust is to be in the 250-260whp range and leater down the road With an ITB setup im looking at around 320whp. Ill keep you guys posted and might do a write up. Who knows
wildweSt2K_93 is offline
Old 12-08-2013, 09:56 AM
Excellent configuration bro !! what throttle body are you going to use????
Nik2k is offline
c32b
08-27-2013 07:39 PM
biker1
12-13-2012 12:08 PM
S2Kitt
05-07-2009 10:34 AM
wherethedevildances
11-12-2008 12:29 PM
StinkyTofu
09-24-2004 08:17 AM
Quick Reply: Brian Crower Stage 2 Cams on an AP1
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
