Camshafts, there must be info on Catcams
Hello all,
I am pretty new to this forum but ill get right to it. I am looking into upgraded camshafts for MY00. Brian Crower stage 2's look promising, and then I see Catcams, they have aggressive non-vtec lobes and high duration. MY00 is running a stock ecu with a VAFC2, I have a K&N CAI and 70mm exhaust from the headers back with a wideband. Anyway I was going to go with the Brian Crowers and install over the winter, but these Catcams look great. Sadly there is no info in the official thread and info for them online is scarce, was hoping someone here is familiar with them.
Thanks
Ryan
Thanks
Ryan
which is strong evidence for them being a waste of money.
why do people want power in this car below 4500 rpm? its built to rev, lower your vtec and call it a day. if you want low end torque, cams are the wrong place to spend money.
spending money to make minute amounts of power in rev ranges that you dont use to drive fast is purelly bench racing stupidity. its not that difficult to keep the car in vtec, and lowering vtec makes it effortless. when im out of vtec, I want gas mileage and smoothness- if someone cut a cam like that(max gas mileage low end), id buy the shit out of it.
but id never ever buy a cam using off vtec power gains as even a thought. vtec fast mode, low cam slow mode
OP, you may have to be the test dummy regarding these cams since the trend on this forum is to boost, keep your f2X stock, or buy overpriced JDM parts. If you decided on theses, I would suggest getting the supporting mods (valve springs, retainers, etc) and upgrading to an EMS since these cams appears to be quite aggressive.
