S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
F24C Long Rod Engine Build 2.4L
Old 01-16-2017, 09:32 AM
  #71
Former Sponsor
BalladeSports's Avatar
Originally Posted by DavidNJ
7) It has a place, or at least sleeved, stroked F-series engines have a place. The K24 conversion, even with a kit, isn't trivial. That said, there was a beautifully done conversion on an AP1 posted recently: https://www.s2ki.com/forums/s2000-na...s2000-1167027/. He used lots of Ballade parts.
Thanks. We are the shop who build Blueprints k24 S2k. Glad you liked it. Thank you for your input on other points you've made. We'll see how this turns out in the end and hopefully this is as successful as we anticipate. It is agreed you can build an even higher displacement with this new deck plate feature. One step at a time. Reliability is still the main focus and horsepower will be what its going to be.
Old 01-17-2017, 02:23 AM
  #72
Mike RT4's Avatar
Do you have any idea when the next updates will be available ?
Old 01-29-2017, 11:22 AM
  #73
JDMpearlwhyteZ's Avatar
Can't wait to see more updates as well.
Old 02-20-2017, 05:28 PM
  #74
Former Sponsor
UPDATE!! PISTONS, CRANK AND RODS! Rotating assembly complete!
Old 02-20-2017, 05:55 PM
  #75
S2000Craig's Avatar
very cool can't wait
Old 02-20-2017, 06:13 PM
  #76
DennisRen's Avatar
Curious to know if you guys installed taller sleeve to match the increased deck height?
Old 02-20-2017, 08:54 PM
  #77
Pabs626's Avatar
This is awesome! cant wait to see the outcome. Subscribed!
Old 02-21-2017, 05:30 AM
  #78
Mrsideways's Avatar
So Eagle Rods, What pistons are those. They look look OEMish. They look A LOT like the RS machine Pistons for a K24.
Old 02-21-2017, 05:54 AM
  #79
Mike RT4's Avatar
No way of repositioning the OEM FRM sleeves?
Old 02-22-2017, 03:48 PM
  #80
Former Sponsor
Yes they are RS 11:1 compression K24 pistons. The original plan was to use Honda 11:1 87mm pistons from the 2013 Honda Civic Si. Unfortunately we got stuck with pistons we cannot use. Here is a look at the Civic k24 87mm piston
If you look at the shape, the high points circled in the photo work for a K series cylinder head, but will not for an F20c/F22c head. K series combustion chambers are dome shaped like the B16a/b18c5. The F20c head camber is much tighter and shaped like a B18c1 GSR head. Those high points in the civic piston will hit the combustion chamber. As of right now we have not found a 87mm Honda K series pistons with a standard type of dome to use. For the sake of time we opted for the RS cast piston for this TEST engine. Once we find a usable Honda piston we will surely change over.
We also wasted money on OEM rods from the 2013 SI, but with fear of the rod strength not being adequate we went with Eagle rods.
Quick Reply: F24C Long Rod Engine Build 2.4L
