S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
F24C Long Rod Engine Build 2.4L
Old 01-29-2018, 12:35 PM
  #241
flanders's Avatar
E92 uses Macpherson struts in the front so that should be very close to motion rate of 1.
Quick google search says 0.96 front and 0.58 rear.
As for the S2k it's 0.589 front and 0.578 rear, at least according to Sakebomb
Old 01-30-2018, 10:24 AM
  #242
Aurex's Avatar
Originally Posted by Mike RT4
https://www.youtube.com/watch?v=3t742T1GwUs
If you scroll to 12:22 in the video, you will see that the 2016 iteration of the J's Racing S2000 "F20C" is 2,670cc ! I wonder what they did to achieve that.....????
There is a forum member with an F27, it's been done before and costs money.
I believe the block is sleeved to accept a larger bore with a 2.4l stroker kit for ~ 2700cc of all motor goodness
Old 01-30-2018, 07:06 PM
  #243
S2kAndTheAnt's Avatar
Yep, I believe he got his engine built my inlinepro.
Old 01-30-2018, 09:12 PM
  #244
Chibo's Avatar
Originally Posted by Slowcrash_101
the motion ratios on e92 basically means the wheel rate is 2.5x less than the spring rate. Wereas our motion ratio means our wheel rate is much closer to the spring rate.
​​​​​​​What I said has nothing to do with motion rates though
Old 10-23-2018, 04:09 AM
  #245
SammyPT's Avatar
Grave diggers on site!
WE NEED MORE INFO!
Old 11-30-2020, 01:52 AM
  #246
rednikos's Avatar
any news here ?
2k2s2k2
05-05-2016 05:19 PM
spessx
02-17-2014 07:37 PM
geared
07-14-2012 06:24 PM
scott-s2k
11-15-2009 09:25 AM
Pixsurguy
11-05-2002 09:10 AM
Quick Reply: F24C Long Rod Engine Build 2.4L
