F24C Long Rod Engine Build 2.4L
#41
How is boring out the stock block, custom sleeves, using a different crank, machining a custom deck plate, machining custom dowels, custom head studs, and modifying a crank to fit in this block in any way simple? All to achieve what, 280whp? This is potentially thousands of dollars in machining and labor alone just for the bottom end for a completely unproven engine to make comparable power to a built K24. All for what, to use the F head? So that it "drops into" an S2000? What?!
It seems like Ballade already found the answer to their question, which is build a K24 with off the shelf parts and drop it in. I admire their willingness to think outside the box, but it seems like they're engineering around the problem (more N/A power) as opposed to just finding a solution.
I promise I'm not trying to attack these guys, it's just.... someone help me understand how the pros of this far outweigh the cons of building a K24.
#43
Go ask him what could go wrong with a k24 swap... LOL!
#45
Originally Posted by cleenyc99' timestamp='1474502992' post='24067233
this engine would theoretically out rev a built k24 by a lot if that helps you. but I see so much that could go wrong its going to take a lot of trial and error
Making an engine swap reliable is no easy task. I've learned a lot. K24 is nothing but a newer F. The timing chain setup is different to accommodate VTC. The motors are remarkably similar. Which is better? I think they are both the same family of engines. You've gotta do things to make the K24 make power, but the taller block gives a better rod ratio which over time should be a better motor. I've probably spent north of $40k since I started the K swap. Being on of the early ones I've done A LOT of trail and error. Something I've learned is a lot of the printed receipts online are just wrong. You do all bolt on parts from an internet receipt and you'll have a 300whp motor at some RPM that is only ok for drag racing and will come apart the moment you try to run the thing hard on track. The bad news is a lot of the money is spent on custom made parts, Custom intake manifold, custom sump baffle, custom header, Custom cams, custom head porting etc etc. I've got a $60k plus S2000 sitting at home that's a cert for distruction race car that I'd be lucky to sell for $25k. I should have just bought a Porsche and made payments. But I've had a ton of fun doing it and that's half of it. I've learned a lot and become a pretty good fabricator. Not afraid to build nearly anything now.
Question for Ballade is how do the plan to address Hood clearance issues. Pushing the head up 10mm or so is probably going to hit the hood.
#46
Originally Posted by BalladeSports' timestamp='1474077915' post='24063685
Now back to the 2.4L stroker kits for F20/22 engine block. Over the years we’ve seen some 2.4L F series engines with massive compression problems and oil burning issues.
What do you mean by massive compression problems?
I haven't experienced any oil burning either..yet..knock on wood
#47
OS Giken do the same type of kit for the RB26 to make it an "RB30".
These run at well over 1000bhp with no reported reliability issues that I have seen in brief searching .
Obviously the best (but most expensive) option would be to have a block cast from scratch with the extra deck height .
#48
Former Sponsor
We have hopes to build this to be as durable as Honda has made the K24 last in all of its platforms. Acura TSX, Accord, CRV, Civic Si, etc. Hoping to achieve 200k miles in longevity and 26 MPG highway.
#49
Former Sponsor
#50
My car is track only with a year of having this motor in the car. I have about 8 track days on it with another one coming up tomorrow. Probably 5-7K (I drove it a lot to see how it would hold up) miles on it with 1k of them being track miles. Not a lot in terms of daily use but it sees a lot of hard miles from track. Most log hours for track use but I dont do that...run it till it blows lol jk
Im still not understanding what major compression issues are. Do you mean loss of compression because of wear? If so, got ya!
BTW, the only thing not OEM in my build are the rods. Everything else is Honda. Head to pan untouched. Great work on this..look forward to more updates.
