Fastest N/A on Nitrous 1/4 mile
May be a dumb question, but is it safe to run a 75 shot on stock internals? I have the kit installed but haven't sprayed it yet. I have heard many different things from locals around here so I thought I'd ask on the forum. Its set up with a window switch and WOT switch and well as monitoring fuel pressure.
Sent from my HTC One X using Tapatalk 2
Stock internals are good for pretty much anything you want to do below 600whp on this car. 75 shot is a cake walk for the engine. Just make sure your AFRs are good when you are spraying and you dont spray too early or hit the limiter with the nitrous on. Just because the engine is strong doesn't mean its idiot proof.
what is the best kit i can run i mean a complete bolt on kit to run on stock S2000 with oem ecu , Nos or Zex etc , model number and etc , i cant find something because ave to much diferent kit
You can run whatever you want untill 75hp in stock ecu.
After ecu update you can decrease timing and you can run untill 100-125..
At 125 and after you need stand alone fuel system.
I am thinking to go for 150hp... I don't know if an s2000 engine can handle more nitrous power....
Dont waste time or effort with a dry shot. Its not worth it. I am currently building an f24 and plan on shooting a 200 shot on it. All the internals are built so I have nothing to worry about. I have seen guys shoot 100 shot on stock internals with no issues.
