going with larger pistons in an F20 rebuild to gain HP
So it appears I may need a rebuild. I wanted to stick as close to OEM as possible to maintain the 9k redline and reliability. Talking with a reputable builder they suggested the possibility of slightly oversized pistons to up the compression to 12.5:1. I could still go to 9k, but would pick up 10-15whp. So I am curious if anyone has any experience with this and if there are any downsides as opposed to trying to staying near or at OEM depending on what the cylinders look like. My thought is that there has to be a downside or everyone would do it?
honda sells a +0.25mm piston, which is the max overbore for a FRM cylinder f series block. that all there is for OEM
if you are talking about boring more than that you will be installing sleeves at that point you can have pistons made to any size/compression you want! bumping compression to 12.5:1 you are going to need a aftermarket ecu so you can effectively tune timing/fuel |
Well that wouldn't be a huge deal, I have a VAFC, but could ditch it and go Kpro. Is there a downside though? The builder was a inline pro and he just suggested it when I said I wanted to make a bit extra HP, but wanted to stay as close to OEM as possible and keep the 9k redline. I just don't see many people going this route, it seems OEM or Stroker are all I see.
if your f20c is toast just buy a used f22c long block and throw it in and use your ap1 ecu. rev it to 9k, its not unheard of.
Originally Posted by bgoetz
(Post 24098846)
Bigger pistons are heavier and with more surface area, adding more rotational mass, this is offset by the benefits of more overall power, but there is still going to be some slight inherent loss of that free revving feeling. A light weight flywheel will more then compensate and highly recommended. Agreed that the 12-15whp is quite optimistic, more realistically its 12-15 engine hp.
A f22 with the stock ap1 ecu is something ive employed with great success in the past long term. If you start getting into lowering vtec though, you need fuel, either mechanically through a adjustable rate fpr or some type of ems that increases injector duty, not a vafc. |
Originally Posted by s2000Junky
(Post 24533892)
I went with the .25mm hone and OEM piston/ring setup on my first S2000 and it turned out great. I would do it again in a New-York-Heartbeat.
An added note. I was going to go aftermarket with sleeves. When the parts came in the speed shop tore down my motor and then called me in for a meeting. When they compared the aftermarket to the OEM, they favored the quality of the OEM and the simplicity of OEM route. I took their recommendation and it saved me a lot of money and turned out just great. |
Originally Posted by nipponS2000
(Post 24534427)
That's something that i'd like to ask many times!So,how is the f22 with the ap1 ecu?Got any problems?You rev it all the way to 9000rpm?How you compare it with the f20?And how about reliability?Got any video with the f22 all the way to 9k?
(Post 24534550)
8500 rpm in the f22 is the equivalent piston speed of the f20 at 9k just fyi.
